2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-03T07:41:30+00:00
    Will a moderator please move the discussions about CPU speeds etc to a new thread....This has nothing to do with firmware screw-ups from: System Firmware Update - 12/10/13 fails to install
    Thank you
    2014-01-03T08:19:43+00:00
    Hmm... What did the December 24th update include? I just checked my device, and it updated it automatically. It says it's a firmware update. It had already been installed :-....
    In regards to the new CPU, yeah, that kind of sucks. Because everyone is going to pay the same amount and they're getting an update CPU. But hey, I got Microsoft Complete and I'm sure sooner or later in the next 2 years I'm going to bust my device and have it exchanged. Who knows! Maybe by then it'll be an even more updated CPU! haha.
    In regard to your first paragraph...
    I have checked my expensive paperweight and even though I have "updates" set at "Check for updates but let me choose whether to download and install them". 5 updates decided they needed to be installed without my permission, no mention of firmware update here!
    In fact we were all gone Christmas Eve...Yet 1 more problem with the pro to add to my list.
    Just run another "sfc /scannow just incase this entity would repair itself...but still "cannot repair" ...missing files. I don't expect a solution on patch Tuesday! I wonder how long the repair will take if they had not worked through the "Holiday period"?
