2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-03T06:54:43+00:00
    Based on the upgraded i5-4300u (also documented in http://news.cnet.com/8301-10805_3-57616508-75/microsofts-surface-pro-2-gets-stealth-silicon-upgrade/) I am taking this firmware issue as a silver lining to get a device upgrade to counter my early adopter penalty.
    The difference is not just clock speed. According to http://ark.intel.com/compare/75459,76308, the 4300u has a faster max graphics frequency and additional virtualization features. That makes it worth a swap in at the Microsoft store for me
    2014-01-03T06:58:19+00:00
    Hmm... What did the December 24th update include? I just checked my device, and it updated it automatically. It says it's a firmware update. It had already been installed :-....
    In regards to the new CPU, yeah, that kind of sucks. Because everyone is going to pay the same amount and they're getting an update CPU. But hey, I got Microsoft Complete and I'm sure sooner or later in the next 2 years I'm going to bust my device and have it exchanged. Who knows! Maybe by then it'll be an even more updated CPU! haha.
