2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-11T14:34:04+00:00
    Well, after several system resets and reloading the firmware and all of the other updates, it appears that the 12/10/13 firmware update is not updating all components to the versions published.
    After a system reset and loading all updates and the 12/10/13 firmware update, my versions are as follows:
    Intel HD Graphics 10.18.3262 (Should be v10.18.10.3345)
    • Marvell AVASTAR WiFi and Bluetooth Driver 14.69.24039.134 (Should be v14.69.24049.160)
    • Surface Type Cover 2 Firmware Update Device (cannot find this on my system (should be v2.0.266.0)
    • Surface Touch Cover 2 Firmware Update Device  - cannot find this on my system,( Should be v1.0.280.0)
    • Surface Pro UEFI  2.04.0250  - This is the correct version
    • Surface Pro System Aggregator Firmware 2.03.0650 - This is the correct version
    • Surface Pro Embedded Controller Firmware 23.07.50 - This is the correct version
    So, it appears that at a minimum, my HD Graphics driver and Marvell WiFi drivers did not update for some reason.  The firmware versions did seem to update.
    Also, I am back to having the unknown device which is the Telemetry driver that does not load properly.
    Lots of issues with this update.
    2013-12-11T15:25:14+00:00
    After getting the failed firmware patch 12/10.
    I stopped the windows update server "net stop wuauserv", renamed the C:\Windows\SoftwareDistribution\DataStore\DataStore.edb" to DataStoreold.edb, restarted the update service "net start wuauserv",
    Then Ran Windows Update Troubleshooter: http://windows.microsoft.com/en-us/windows-8/troubleshoot-problems-installing-updatesThen restarted just to be sure of things, then ran disk cleanup "Clean up system files", and made sure the windows update files were selected for cleanup.After that restarted again for kicks.  And re-ran regular Windows update.  After that it downloaded the firmware patch and installed with zero issues.Perfect Device version matchup in device manager.Hope it helps someone.
