2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-03T03:36:56+00:00
    ......this really annoys us early adopters.  I had mine pre-ordered and delivered on day one.
    [edited for politeness by moderator] I imagine if you read the fine print on the Windows Store web site, you'd have noticed that it says 'Microsoft reserves the right to change the device specs at any time.' So you ignored this?
    I ignored it just as anyone who does not read the Terms and Conditions of iTunes etc. does.  Or are you saying you read every word of that?
    GIve me a break.  It's not the change itself, it's the fact (a) no SKU change so that any resellers will have to be super clear about what they are selling,, b) it's only been two months.  I'd expect a change down the road, but not yet.
    I'm unclear on what your fact (a) has to do with you being an early adopter?  I'm pretty sure the resellers will be fine.  You can barely find any in stock anywhere right now, so having old stock on the shelf shouldn't be much of a problem for them.
    Regarding (b), technology changes fast.  It could be the i5-4200U SKU is being phased out and Intel is providing 4300U's.  Who knows.  It's a pretty minor change.  Changes (hardware and prices) happen all the time with computers.  It's not like MS is doubling storage or resolution for the same price.  It's a minor jump in speed. Not the big deal you're making it out to be.
    2014-01-03T03:45:06+00:00
    I don't think anybody is saying MSFT isn't allowed to make such change. But suppose you buy one today and ships, do you know which one you got because I.M.O, a surface with the Intel 4300u is a different product than one with the 4200u, and if I can buy both and both cost the same, shouldn't I know this? I don't see a drop down to order either one, and also my surface pro 2 box doesn't state the CPU it uses.
    Everywhere I look, online, I don't see that the Surface Pro 2 specs saying anything other than "4th generation i5".  Both CPU's are definitely that.  I also think most people are not aware (or care).  If you are (aware) and do (care) then be sure to buy someplace that has an easy return policy.
    Upping the CPU for the same price...who can complain?  :)
