2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-03T02:39:51+00:00
    There is a 17% clock difference which will be noticeable for single threaded CPU dependent apps.
    Also the new chip has a few extra security extensions that the old one doesn't.
    I don't think anybody is saying MSFT isn't allowed to make such change. But suppose you buy one today and ships, do you know which one you got because I.M.O, a surface with the Intel 4300u is a different product than one with the 4200u, and if I can buy both and both cost the same, shouldn't I know this? I don't see a drop down to order either one, and also my surface pro 2 box doesn't state the CPU it uses.
    So what are the choices of somebody who wants to get the 4300u since there is no way other than opening the box to tell? The answer to this, is something MSFT should provide. Not because they must, but because it is the right thing to do for their customers. When is that a bad thing?
    2014-01-03T02:56:03+00:00
    This is getting really old. While every bodies current model of SP2 is screwed up, Microsoft then upgrades the CPU on the new model. And waiting for patch Tuesday is bull! Microsoft should lock the proper people in a room and not let them out until there is a patch quickly. Get your **** together Microsoft. I've owned both SP1 and 2. This is your damned premium device. Get it done NOW. Or you can count on me not buying a SP 3!
