2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-03T02:13:30+00:00
    The moderator in editing my preceding post for "politeness" also edited out the observation that the spec difference between the 4200U and the 4300U is nowhere near the difference in specs for the Broadwell processor that is about to make all our SP2's look pretty obsolete in about 10 months, if not sooner.
    10 months is a lot different than two.   It's NOT the MINIMAL spec change in and of itself ... as I am in the tech industry I understand it's a minimal change.  It's the principal.  When you are an early adopter -- as in day one -- you don't expect to see something like this happen.
    2014-01-03T02:14:41+00:00
    the processor was upgraded to a i5 4300U
    First I've heard of it, but you're not alone:
    http://browser.primatelabs.com/geekbench3/search?utf8=%E2%9C%93&q=Surface+Pro+2
    Maybe I should pit in for a replacement instead of waiting for this fix. It would be worth reinstalling everything if it guaranteed a specs bump.
    Does CPU-Z agree it's a 4300? http://www.cpuid.com/softwares/cpu-z.html (download link on right hand side)
    If this is true, I and any other early adopters will be extremely angry.
    well time to get angry.
    http://www.theverge.com/2014/1/2/5266988/surface-pro-2-intel-i5-processor-updated-specifications
    can this get any worse? my surface is limping and it's resale value just went down. seriously!
    Yup, I was just about to post this: http://www.winbeta.org/news/replacement-surface-pro-2-devices-being-sent-out-upgraded-specs-includes-newer-cpu
    I could understand if it was, say, six months (perhaps), but this really annoys us early adopters.  I had mine pre-ordered and delivered on day one.
    It's not that the people who got 4200Us were unlucky or wronged in any way; it's simply that the people who got the 4300Us were lucky. There's a difference.
    We all bought the machine having seen it advertised as 4200U. That people are now getting a 4300U shouldn't make us upset, even if it's notably faster.
    We should focus on getting answers and fixes for the firmware problem. That's a complete screw-up, and for that, we deserve better answers.
