2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
  1. Deleted
    2014-01-03T02:11:28+00:00
    ......this really annoys us early adopters.  I had mine pre-ordered and delivered on day one.
    [edited for politeness by moderator] I imagine if you read the fine print on the Windows Store web site, you'd have noticed that it says 'Microsoft reserves the right to change the device specs at any time.' So you ignored this?
    I ignored it just as anyone who does not read the Terms and Conditions of iTunes etc. does.  Or are you saying you read every word of that?
    GIve me a break.  It's not the change itself, it's the fact (a) no SKU change so that any resellers will have to be super clear about what they are selling,, b) it's only been two months.  I'd expect a change down the road, but not yet.
