2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-02T22:08:28+00:00
    ......this really annoys us early adopters.  I had mine pre-ordered and delivered on day one.
    [edited for politeness by moderator] I imagine if you read the fine print on the Windows Store web site, you'd have noticed that it says 'Microsoft reserves the right to change the device specs at any time.' So you ignored this?
    2014-01-03T01:26:19+00:00
    The moderator in editing my preceding post for "politeness" also edited out the observation that the spec difference between the 4200U and the 4300U is nowhere near the difference in specs for the Broadwell processor that is about to make all our SP2's look pretty obsolete in about 10 months, if not sooner.
