2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-02T20:09:16+00:00
    the processor was upgraded to a i5 4300U
    First I've heard of it, but you're not alone:
    http://browser.primatelabs.com/geekbench3/search?utf8=%E2%9C%93&q=Surface+Pro+2
    Maybe I should pit in for a replacement instead of waiting for this fix. It would be worth reinstalling everything if it guaranteed a specs bump.
    Does CPU-Z agree it's a 4300? http://www.cpuid.com/softwares/cpu-z.html (download link on right hand side)
    If this is true, I and any other early adopters will be extremely angry.
    well time to get angry.
    http://www.theverge.com/2014/1/2/5266988/surface-pro-2-intel-i5-processor-updated-specifications
    can this get any worse? my surface is limping and it's resale value just went down. seriously!
    2014-01-02T20:56:31+00:00
    Yup, I was just about to post this: http://www.winbeta.org/news/replacement-surface-pro-2-devices-being-sent-out-upgraded-specs-includes-newer-cpu
    I could understand if it was, say, six months (perhaps), but this really annoys us early adopters.  I had mine pre-ordered and delivered on day one.
