2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-02T18:18:21+00:00
    Just read one user was told MS wants to wait for the next patch Tuesday to fix this problem. Unbelievable! Massively unnaceptable.
    When they first pulled the update, that was their stance, to be replaced by the "working over the holidays" message.  Considering that Patch Tuesday is only 12 days away, they may have said "working over the holidays" but may hold the fix until then.
    2014-01-02T19:58:12+00:00
    Well, next Tuesday is an ETA (estimated time of arrival) anyways!  I'm in a holding pattern to see if the patch will fix my Surface Pro 2  512GB 4200 CPU.
    I've turned off all updates until "the Patch" comes out, then I'll turn them back on selectively.
    I'm backing everything up first.
    I'm hoping it works.
    If not, I'm wondering if a "RESTORE"  to factory settings will put things back to square one.  I wonder if the bad firmware update would linger on even in a "RESTORE"?  (This is my real question... whether to bother or not.)
    Not only do I have the battery problems and sleep and awake problems, my machine also no longer has an Activated Windows and refuses to install all Windows Updates... even when turned on.  They install... then go through a fail mode and uninstall.  I don't know how the patch will download.
    I get the Activate Windows screen multiple times throughout the day and also get Error 800 when trying to Activate Windows.
    I already did a system "REFRESH" and lost all my programs.  It got my internet back for my Surface Pro 2, but not for the Windows Operating System.
    Thoughts...
