2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-02T17:53:23+00:00
    I would be extremely upset as well if they updated the processor. I paid an equal amount for the same product line, but weaker processor. On the otherhand, it's been 3 weeks + and the battery life is driving me nuts. It stays at 100 %, doesn't sleep, and overheats my SP2. I'm really considering a replacement....
    2014-01-02T18:12:40+00:00
    let's not get OT, but the only difference between those two chip models is the multiplier. the 4300 has a higher multiplier = higher power consumption and higher heat. it's just physics. If you could change the multiplier on the 4200U you could make it a 4300U. it's a basic intel profit strategy well know and understood.
