2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-02T16:25:45+00:00
    I exchanged my SP2 because I did not want to be stuck with a $1300 device that is not 100% since it was only two weeks old. The new one has an improved CPU i4300U versus the one I returned has a 4200U.
    proof? it's not that I don't believe you but I'm skeptical of this. MSFT hasn't announced any such change and it isn't as easy as just dropping in a new chip when you consider it would amount to a new SKU and a change in processor is unheard of in any surface tablet ever released under the same SKU.
    regardless, it doesn't seem likely. The higher clock speed on this chip would mean higher power usage and more heat generation. The reason they went with the 4200U was to keep battery life and silent operation first. Unless they did some re-design (unlikely) or some aggressive firmware tweaking (after this even more unlikely) then a 4300U surface will be a hotter more power hungry device.
    2014-01-02T16:57:40+00:00
    Look here to see the spec comparison of the i5-4200U cs i5-4300U.  Same MAX TDP (watts)  and temps so, does it really run hotter and consume more power??
