2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-02T12:37:50+00:00
    Does Microsoft have a bug tracker site where we can post defects and get responses from their development team ? It would be nice if Microsoft were a bit more open about the issues and involved the community rather than shutting us out and pretending we don't exist!.  A lot of us have vast years of experience in the IT field and would like to contribute especially if it means making our expensive systems (toys) more stable.
    2014-01-02T13:01:04+00:00
    Sounds familiar.  Ever heard of a company called Apple?  Microsoft must be following in their footsteps.
