2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-11T12:54:05+00:00
    Partial solution to this issue of Not even installing the updates (updates not needed message) was to hold the power button along with the volume up key (I believe this releases the secure boot key - not sure).  Then after a couple reboots, run windows update a few times and it downloaded and installed the 12 updates with no problems, firmware detected as failed though...
    2013-12-11T13:43:44+00:00
    Does anyone know when they will release the December update for Enterprise customer for downloading? The link to the Surface Pro 2 Firmware and Drivers is still handing out the October 2013 updates.
    Seeing all the failures I'm interested to have the actual content so I can do the install of the drivers manually and see what and why things are failing. I've get a few test devices which I'll just reimage with our Enterprise image should anything go wrong so no concern there.
