2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-02T08:27:14+00:00
    Yeah. Right. It's already January 2nd.
    They didn't say WHEN it would be released. All they said was that they were going to work through the holidays.
    Regardless, the holiday season doesn't end until after Jan 6th, which is the epiphany, in a lot of countries. Relax.
    2014-01-02T08:48:08+00:00
    The fact that they haven't said when it would be released is precisely why I don't buy that they they've been working on a fix over the holidays.
    This isn't a major version changing release. It's a patch to reverse a broken update. It changes one thing. It's unreasonable that 20 days in there still isn't a release time estimate.
