2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-02T07:30:38+00:00
    the processor was upgraded to a i5 4300U
    First I've heard of it, but you're not alone:
    http://browser.primatelabs.com/geekbench3/search?utf8=%E2%9C%93&q=Surface+Pro+2
    Maybe I should pit in for a replacement instead of waiting for this fix. It would be worth reinstalling everything if it guaranteed a specs bump.
    Does CPU-Z agree it's a 4300? http://www.cpuid.com/softwares/cpu-z.html (download link on right hand side)
    If this is true, I and any other early adopters will be extremely angry.
     Indeed. As a 256GB SP2 owner, I would feel cheated by Microsoft if this turns out to be true. I had to check a lot of local retailers and wait a long time to get my computer because I wanted to use it for sketching and 3D modeling and needed the extra RAM in the 256GB and 512GB models. I'm quite happy with my Surface, but I would hate to see other users getting a more powerful device having paid the same I did.
    Once this is confirmed, one question remains, though. According to what I have read online, 4300U is more powerful and feature packed than 4200U, but 4200U in turn seems to have much better performance per watt. If SP2's shipped with 4300U have the same battery model as the ones with 4200U, shouldn't they have shorter battery life?
    In any case, making such a major change in a product's specifications just as it is starting to become available at stores is an insult to customers everywhere. In one word: unacceptable.
    2014-01-02T08:02:24+00:00
    Yeah. Right. It's already January 2nd.
