2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-02T03:31:32+00:00
    I've been having the same issues. 100% - 7 hours, then 90% - 5 hours, etch so much fluctuation!
    Sometimes its stuck at 70% - not charging. Turns out its already at 100% post reboot.
    2014-01-02T03:51:40+00:00
    the processor was upgraded to a i5 4300U
    First I've heard of it, but you're not alone:
    http://browser.primatelabs.com/geekbench3/search?utf8=%E2%9C%93&q=Surface+Pro+2
    Maybe I should pit in for a replacement instead of waiting for this fix. It would be worth reinstalling everything if it guaranteed a specs bump.
    Does CPU-Z agree it's a 4300? http://www.cpuid.com/softwares/cpu-z.html (download link on right hand side)
    If this is true, I and any other early adopters will be extremely angry.
