2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-02T02:57:17+00:00
    the processor was upgraded to a i5 4300U
    First I've heard of it, but you're not alone:
    http://browser.primatelabs.com/geekbench3/search?utf8=%E2%9C%93&q=Surface+Pro+2
    Maybe I should pit in for a replacement instead of waiting for this fix. It would be worth reinstalling everything if it guaranteed a specs bump.
    Does CPU-Z agree it's a 4300? http://www.cpuid.com/softwares/cpu-z.html (download link on right hand side)
    2014-01-02T03:01:21+00:00
    I exchanged my SP2 because I did not want to be stuck with a $1300 device that is not 100% since it was only two weeks old. The new one has an improved CPU i4300U versus the one I returned has a 4200U.
