2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-02T02:40:06+00:00
    I am not an IT guy.  Did Microsoft release a Surface Pro 2.5?
    I returned my Surface Pro 2 (v. 256GB) because of the poor performance after the failed12.10.13 firmware update. I recall the SP2 I returned having a i5 4200U processor.
    To my surprise, when I checked the System Properties in the Control Panel on my replacement SP2, the processor was upgraded to a i5 4300U @ 1.9Ghz. - 2.5 Ghz.
    Perhaps this is old news. Can anyone explain this change? Thank you.
    2014-01-02T02:47:54+00:00
    So what should I do? I have till Friday to return this thing Because I'm an elite bestbuy member.  I've had it for almost 30days. I wish Microsoft would give us a better time line and if it's a hardware issue or not. Are we going to be dealing with power problems for the long haul?
    I'd return it and buy again when there's a fix.  However, There will be a fix eventually so if you can live with it...
