2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
  1. Deleted
    2014-01-02T02:33:34+00:00
    The SP1 is not affected by the bad firmware.  Only the SP2 is.  You are safe to install the update.
    Installed and now my WIFI won't connect to anything.  :(
    It looks like the December Updates does an update on the Marvell WiFi adapter.  I put the driver back to the version it was before the update, but still it won't connect.
    Update:  it was a problem with the Sonicwall GVPN client.  Fixed.  :)
