2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-01T22:33:26+00:00
    So what should I do? I have till Friday to return this thing Because I'm an elite bestbuy member.  I've had it for almost 30days. I wish Microsoft would give us a better time line and if it's a hardware issue or not. Are we going to be dealing with power problems for the long haul?
    2014-01-02T01:31:28+00:00
    Just got my Surface PRO (1) yesterday at Best Buy at a big discount, so I thought it worth it to take the plunge and try it out.
    Doing all the updates and going to Windows 8.1 Pro, I noticed now that one of the updates was a "System Hardware Update 12/10/13".  I checked here before installing it, and I thought MS pulled this update?  Why is it showing on my Windows Updates?
    I have disabled this update, hoping to circumvent the issues you all are having.  Is this the right thing to do?
    Also, I have no SLEEP option in my power settings now.  Is that because of something that another update has done?  I see Hibernate, but no option to SLEEP (for instance on closing the lid or pressing the power button).
    Please advise.  Thanks!
    The SP1 is not affected by the bad firmware.  Only the SP2 is.  You are safe to install the update.
