2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-01T12:22:02+00:00
    "a fix for the small number of customers"
    Yeah! It's only a few customers ... hahahaha.
    2014-01-01T15:19:13+00:00
    Just got my Surface PRO (1) yesterday at Best Buy at a big discount, so I thought it worth it to take the plunge and try it out.
    Doing all the updates and going to Windows 8.1 Pro, I noticed now that one of the updates was a "System Hardware Update 12/10/13".  I checked here before installing it, and I thought MS pulled this update?  Why is it showing on my Windows Updates?
    I have disabled this update, hoping to circumvent the issues you all are having.  Is this the right thing to do?
    Also, I have no SLEEP option in my power settings now.  Is that because of something that another update has done?  I see Hibernate, but no option to SLEEP (for instance on closing the lid or pressing the power button).
    Please advise.  Thanks!
