2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-01T03:06:11+00:00
    I did a shutdown of my Surface Pro 2 today before leaving work, Have it set to hibernate with the lid closed, got home took it out of the case and it was on and hot.  Still waiting on Microsoft to fix this $1000.00+   problem.
    This is what happens to me, also. As I mentioned in a post a moment ago to MJfri, after numerous trial and error tests, I"ve learned that leaving the microSDXC card out is essential to getting the unit to shut down, hibernate, and/or sleep properly.
    That doesn't fully fix it -- my battery meter is still virtually inoperable - I do the vol up/power off 15 second full shutdown to get it to show the correct charge, then it goes back to not working again).
    But at least leaving the microSDXC card out means I don't pull it out of my travel bag smoking hot anymore. And when I shut it down, it stays shut down.
    2014-01-01T09:43:09+00:00
    Here is my update...I did the "Disk Cleanup" on the 12/13/2013 after I came here looking for help…
    Now today I have lost all System Restore points. I did have 3 "points" after the rollback; 12/03/2013, 12/13/2013 and 12/18/2013. (Courtesy of OneNote Screen clipping) Now a Red X, "No Restore points have been created etc: etc."
    I have corrupted 'cannot repair' files when I run System File Checker ("sfc /scannow") in Command Prompt (Admin)
    I still have issues with waking from SHUTDOWN with power adapter plugged/unplugged after rollback...With the micro SDXC card removed!
    Event Viewer has enough info to paper an entire room…CBS file will do the second room.
    I always "Shutdown", never enter sleep or hibernation…AND since "corruption event": left standing up...rarely used!
