2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-01T02:46:52+00:00
    Josh,
    Thank you,
    Tim
    Any progress to report?
    I'd much prefer a fix than have to go for a replacement.
    2014-01-01T03:00:50+00:00
    I have allowed my SP2 to automatically install all updates. Like everyone else here I had the sleep problem, so I totally disabled sleep and switched to hibernate, as I suggested many posts ago. I had to reset once to get my battery level right. I can live with my tablet taking a little longer to wake from hibernation, but I have not had a crash in ages (crossing fingers) nor has my tablet woken up at unexpected times, in short if I pretend sleep mode does not exist, my tablet works well, as far as this is concerned. The SD card is always in and the type cover is always attached (though I have to detach it sometimes because it seems to lose power occasionally - but that's a different issue).
    I'm glad this is working for you, but I'd like to be clear  it isn't working for me. I've tested sleep, hibernate, and full shutdown with and without the microSDXC card in and the card always causes problems. I have to keep the card out when I'm sleeping, or hibernating, or full shut down, to avoid problems. Doesn't make any sense to me, but there it is.
