2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-11T12:42:34+00:00
    Same error Code for me after Windows Update: Surface Pro 2 8/256 GB. (Sweden)
    2013-12-11T12:52:30+00:00
    Performed a full system wipe and the failed update went through okay... with minor issues regarding:
    1. The Wi-Fi / Bluetooth drivers which could be found here,
    2. The telemetry device which simply needed to be uninstalled, then disabled, then re-enabled, then its driver updated over the internet in order to work.
    All shutdown & sleep operations tested and worked fine, system ran cooler, battery life meter maybe at times inaccurate.... damn Microsoft.
