2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-01T01:53:37+00:00
    Personally, seems to me that if you know that your Surface Pro 2 has a problem with spontaneously waking up that putting it in a case and leaving it there is about like slipping a cartridge into a revolver and playing Russian roulette.
    Perhaps the current state of our Surfaces is partly dependent on exactly what each of us did after the 12/10/13 firmware update.  I immediately ran the Windows Update Troubleshooter, then applied Dylan Tullberg's fix (p.1 of this thread).  Since then, thinking all was well, I've had one instance where I found my SP2 had come on twice in succession over a period of hours and was warm inside its case.  Don't know whether I absent-mindedly failed to shut it down, as I usually do, or hit the Power button while gripping it tightly in its case or whether my device still does have zombie tendencies.  But since then, I've put it in Airplane Mode before shutting down, used either the Settings, Power icon option to shutdown, or run "Shutdown /p" from the Administrative Command Prompt.  Have not had any issues with waking up since then (~12/20/13) and I check my machine's suspended behavior every day by "powercfg /batteryreport"
    Would be an additional pain to switch out of Airplane Mode as well as having to boot from a complete shutdown but maybe it's worth a try to see if that can help you out until a fix is available.
    This is the fishiest fault i've ever come across... where one suggestive fix won't work for another. There is more to this within MS departments.
    2014-01-01T02:11:26+00:00
    I have allowed my SP2 to automatically install all updates. Like everyone else here I had the sleep problem, so I totally disabled sleep and switched to hibernate, as I suggested many posts ago. I had to reset once to get my battery level right. I can live with my tablet taking a little longer to wake from hibernation, but I have not had a crash in ages (crossing fingers) nor has my tablet woken up at unexpected times, in short if I pretend sleep mode does not exist, my tablet works well, as far as this is concerned. The SD card is always in and the type cover is always attached (though I have to detach it sometimes because it seems to lose power occasionally - but that's a different issue).
