2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-31T21:57:11+00:00
    I did a shutdown of my Surface Pro 2 today before leaving work, Have it set to hibernate with the lid closed, got home took it out of the case and it was on and hot.  Still waiting on Microsoft to fix this $1000.00+   problem.
    2014-01-01T00:02:55+00:00
    Personally, seems to me that if you know that your Surface Pro 2 has a problem with spontaneously waking up that putting it in a case and leaving it there is about like slipping a cartridge into a revolver and playing Russian roulette.
    Perhaps the current state of our Surfaces is partly dependent on exactly what each of us did after the 12/10/13 firmware update.  I immediately ran the Windows Update Troubleshooter, then applied Dylan Tullberg's fix (p.1 of this thread).  Since then, thinking all was well, I've had one instance where I found my SP2 had come on twice in succession over a period of hours and was warm inside its case.  Don't know whether I absent-mindedly failed to shut it down, as I usually do, or hit the Power button while gripping it tightly in its case or whether my device still does have zombie tendencies.  But since then, I've put it in Airplane Mode before shutting down, used either the Settings, Power icon option to shutdown, or run "Shutdown /p" from the Administrative Command Prompt.  Have not had any issues with waking up since then (~12/20/13) and I check my machine's suspended behavior every day by "powercfg /batteryreport"
    Would be an additional pain to switch out of Airplane Mode as well as having to boot from a complete shutdown but maybe it's worth a try to see if that can help you out until a fix is available.
