2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-31T12:34:22+00:00
    it's not good to say to a customer, it will be ready when it's ready ? Which seems to be what MS are saying, borderline ignorance perhaps. Its not unfair to ask for a timeline, is it ?
    2013-12-31T13:06:29+00:00
    I wonder if the responsible programmer still works for Microsoft because he caused quite a big financial issue (and image, too).
