2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-31T02:03:14+00:00
    well this is horrible. only 2 days away from 2014 and we still don't have a fix. tomorrow it will be 3 weeks waiting. Some users have called for patience but I have to wonder if this was a google or apple flagship product, will they not have fixed it by now.
    It is simply beyond reasonable that Microsoft can't fix its own software with its own hardware. Talk about an end to end scenario they control and yet week 3 went without a single positive development....
    Considering there are issues with the Android 4.3 release that hose just about every BT keyboard many have tried, I'm not sure I'd go that far with Google.
    A BT keyboard problem on a phone isn't on the same magnitude as your tablet essentially cooking itself inside your bag whenever it feels like it... And let's be clear here: MSFT is letting down its biggest fans that got this device at a huge premium. Standing by your customers isn't something that should be up for debate here.
    That's not the point.  The point is it affects -- apparently -- ALL 4.3 tablets.  That's more devices than SP2 sales (and I say this as an owner of both devices affected by both issues).  Meaning I'm no fanboy of either; I'm being fair here-- considering the number of complaints about the BT issue, this should have been fixed by Google long ago.
    2013-12-31T03:06:49+00:00
    I don't exactly know what you're talking about, so I can't judge. But I do use Android 4.3 as well. I know this is outside of this forum's purposes and intents, but can you tell us exactly how it effects your bluetoothing  experience?
