2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-30T19:32:48+00:00
    I concur.  This is an epic fail on their part.  So what if it is the holidays, this is a product they have touted as being a replacement for a tablet, laptop and desktop and I took them at their word.  This is my primary computer now.  Yes, I can set it to hibernate to make sure the battery doesn't drain, but that wasn't part of the deal when I bought it.  It was supposed to be fully functional whenever I needed to use it and in whatever configuration I choose to use.  Their silence on this for an extended period of time tells me they have no idea how to fix this yet.
    2013-12-30T22:05:43+00:00
    Same question for me regarding the 'Big Fix'...
    I got a replacement yesterday and have gone through the process of re-installing everything etc etc (horrible)... but! I made sure not to install the firmware update... only the security and driver updates.  I left my SP2 at 78% battery last night... closed the lid and woke to it at 77% this morning (hibernates).  So, I'm guessing it's all good.
