2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-30T17:25:15+00:00
    I am equally unable to understand your comment. Perhaps you're on the MS OS development team? If so everything begins to make some kind of sense.
    Let me reduce it to one simple question which you may be able to grasp.
    Why is it now no longer possible to investigate the nature of the updates (by looking at the associated KB entries individually) prior to installing them? In the past this was always the case.
    2013-12-30T19:16:16+00:00
    Well, I don't know the specifics of Microsoft but they essentially have in practical terms an unlimited amount of money, and unlimited ability to hire, and an unlimited amount of equipment purchasing power. My company doesn't have none of those, and if we broke people's systems for more than a week without at least a reliable rollback strategy we'd be out of business.
    Specially given the importance of the "devices and services" strategy, you'd think MSFT would have a contingency or emergency plan before releasing a firmware update just as half the company is getting ready to hit the slopes of Washington state.
