2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-30T16:03:55+00:00
    well this is horrible. only 2 days away from 2014 and we still don't have a fix. tomorrow it will be 3 weeks waiting. Some users have called for patience but I have to wonder if this was a google or apple flagship product, will they not have fixed it by now.
    It is simply beyond reasonable that Microsoft can't fix its own software with its own hardware. Talk about an end to end scenario they control and yet week 3 went without a single positive development....
    2013-12-30T17:07:14+00:00
    if they missed this on their internal testing, one must admit that they have to do quite a lot of change to their strategies before releasing a possible fix.
    This is also a difficult time of the year with many people having days off work, and generally speaking, it takes time for the issues to be isolated, fixed and tested.
    Working in the software development area myself, I completely understand that it might take longer than what seems reasonable, but releasing another half-assed patch would only make things worse.
