2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-30T15:22:41+00:00
    I'd like a couple of simple clarifications.
    After the "looping" update problem which required a system restoration to re-establish a usable device I have stopped installing ANY updates.
    **1)**It now seems, unlike my experience of innumerable earlier versions of the OS, that it is no longer possible to first check what the nature of the updates are by reading the KB entries for each of them prior to installing. Is this the case and if not, how do I locate the information?
    2) When (if) the Big Fix appears can I simply install it having bypassed some (which?) preceding updates? And how, given the above, do I determine what's required?
    This is an appalling mess.
    If I read 1) and the first part of your post, I really wonder how you came up with 2)... Or at least, how you come to expect anyone to answer 2) properly.
    I agree that it appears as if the December updates messed with power states. But this thread and the way people state their opinion makes it seem worse than it is... This post certainly qualifies for the latter of my statements. (Just my opinion).
    2013-12-30T15:27:24+00:00
    Agreed, especially as this is a 'premium product', let's hope for a quick fix & can put this mess behind us.
    So, still no answers (from Microsoft) to these questions. Which you'd have thought were not unreasonable to ask.
    Answers please.
