2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-30T12:07:15+00:00
    I'd like a couple of simple clarifications.
    After the "looping" update problem which required a system restoration to re-establish a usable device I have stopped installing ANY updates.
    **1)**It now seems, unlike my experience of innumerable earlier versions of the OS, that it is no longer possible to first check what the nature of the updates are by reading the KB entries for each of them prior to installing. Is this the case and if not, how do I locate the information?
    2) When (if) the Big Fix appears can I simply install it having bypassed some (which?) preceding updates? And how, given the above, do I determine what's required?
    This is an appalling mess.
    2013-12-30T12:31:42+00:00
    Agreed, especially as this is a 'premium product', let's hope for a quick fix & can put this mess behind us.
