2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-11T12:16:58+00:00
    For the 12/10 Surface Pro 2 256 updates I'm getting: "The updates were installed: Not needed 13 updates"
    Nothing is downloaded no new firmware installed now.  Update history shows some odd behavior.  Apparently the system firmware update of 10/24/2013 was installed twice.  And some odd multiple failures of English Input Dictionary.
    Wish I could get the firmware update to fix the buggy screen dimming issues when watching video.  MS dev firefighting must be common and devs overworked.
    2013-12-11T12:32:26+00:00
    The same thing has happened for me... Windows update says the firmware update failed with error 80070490.  I am not offered to retry the update.
    Failed for me too with this same error message. Also not given another chance to install the update.  When I check for updates this update this update is not offered even though it failed.
