2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-30T10:48:15+00:00
    Josh,
    Thank you,
    Tim
    Joke, right small number of customers, I cant use my machine off charge, honestly you go about ruining your most prestigious device, so we can start the new year with machines not fit for purpose, way to go!
    As far as I know, my 2 x American friends received the December update, then another one (same dated update) the next day which fixed it. Best way to know... Honk if you're an Aussie! Me HONK HONK!
    Update: I manually counted  138 users in this forum, give or take.
    2013-12-30T11:12:22+00:00
    Your missing the point - this device primary purchase is for portability & it fails 100%.
    How long does your battery last? I think you might have a defective unit if it fails 100%. My issue WAS battery drain OVER NIGHT. Not being able to take it off the charger. Even with the bug, my device was 100% functional and battery life was fantastic with the screen on. From what I read, the issue is due to sleeping incorrectly and waking up in the middle of sleep after the first hour. Hibernation fixed the issue for a lot of people. I'd suggest looking into getting a new device if it, as you state, 100% fails at it's job. Even with this bug I get 5-8 hours of screen on time every day. I have to TRY HARD to kill it (or leave it in sleep mode at night haha)
    Hi - My battery is fine - it displays the same symptoms as reported in this forum - A reboot restores it to working - but battery, sleep/ wake & hibernation behaviour are erratic & unstable -
    For now, I just use 'shutdown' when not using the SP2 & power up when I need it - this works for now - but is a pain as I like to just resume & continue work where I left off - and while the device is quick to boot - it does not replace the even quicker 'wake' with all my apps running.
    /T
