2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-29T17:28:44+00:00
    Using hibernate instead of sleep makes it lose it's portability?  Used my SP2 at the airport and on the plane and it performed perfectly.  Since using hibernate instead of sleep I'm back to charging just once a day, easy workaround until the firmware is updated.  Maybe your holding it wrong.
    I'm using sleep mode effectively after setting the sleep/hibernate times under Advanced Power Settings to Sleep after 10 minutes and Hibernate after 12 hours (720 minutes). Since I use it at least once every 12 hours, it effectively never tries to go from Sleep to Hibernate which is apparently where the bad behavior occurs.
    If I'm not going to use if for a long while, I shut it down.
    I always eject my microSDXC card before shutdown or sleep (basically I leave it hanging out in the slot except when needed).
    This combination is working. But I really hate that this expensive device requires this kind of wonky work around. If I hadn't spent my hard earned money, I might find all this no big deal. But having spent hard earned money my tolerance for this foolishness is non-existent.
    2013-12-30T09:37:01+00:00
    Josh,
    Thank you,
    Tim
    Joke, right small number of customers, I cant use my machine off charge, honestly you go about ruining your most prestigious device, so we can start the new year with machines not fit for purpose, way to go!
