2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-29T16:09:59+00:00
    Using hibernate instead of sleep makes it lose it's portability?  Used my SP2 at the airport and on the plane and it performed perfectly.  Since using hibernate instead of sleep I'm back to charging just once a day, easy workaround until the firmware is updated.  Maybe your holding it wrong.
    Do you have to reset every couple of days to remind device of it's battery capacity?
    Do you shut it down only to come back and find it on?
    Are you 100% comfortable trusting the device out & about on a 40 degree day?
    I'm glad you're happy, sincerely I am. I'm just not sure why people (not only you) feel the need to belittle those simply asking for a fix.
    2013-12-29T16:41:49+00:00
    No for the most part, using hibernate instead of sleep keeps battery capacity from displaying incorrectly but if hibernate doesn't take this can happen.
    No, as I use hibernate and so the device doesn't wake on it's own.
    Celsius or Fahrenheit?
    Not belittling the issue, this broken firmware needs to be fixed, but I don't agree that the SP2 is unusable until that happens.  There is a workaround that can be used in the mean time, the only point I'm trying to get across.
