2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-29T13:51:08+00:00
    Do you know that there's a famous workaround by holding power+volume up button to fix the battery reading issue? It sounds to me like you didn't know there's a workaround to this problem yet and that's why you think the device is unusable now...
    What I ended up doing was shutting down and then power up while pressing the volume up button and restoring the UEF or something like that to the default. Which I think is what fixed my issue, I think. I have the MicroSD card installed always and I don't get any wakeups.
    But I have to admit I never just close the cover (type cover 2), I slide from the right side and click the power and hibernate or sleep.
    2013-12-29T13:54:12+00:00
    Your missing the point - this device primary purchase is for portability & it fails 100%.
    How long does your battery last? I think you might have a defective unit if it fails 100%. My issue WAS battery drain OVER NIGHT. Not being able to take it off the charger. Even with the bug, my device was 100% functional and battery life was fantastic with the screen on. From what I read, the issue is due to sleeping incorrectly and waking up in the middle of sleep after the first hour. Hibernation fixed the issue for a lot of people. I'd suggest looking into getting a new device if it, as you state, 100% fails at it's job. Even with this bug I get 5-8 hours of screen on time every day. I have to TRY HARD to kill it (or leave it in sleep mode at night haha)
