2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-29T13:08:30+00:00
    While I understand everyone's frustration I do think that some people are exaggerating. I paid a lot of money for this device, too. And to be honest, I had one day where I had the battery drain and ever since I've been having pretty much constant good battery life in sleep and hibernate mode with and without micro sd card installed. I hibernate manually, not with closing the lid, and that has seemed to do the trick for my device. Now, to call it unusable I think is unfair. Apple has had its share of lousy updates as well, so don't think that switching with eliminate your problem. I think the best thing to do is just be patient. This is Microsoft's baby, they should take better care of it. I for one am very happy with my device. I think battery life is superb and the portability of this device over many others is far superior. Can battery life be better since the update? Yes. Will Microsoft fix this? For sure, unless they want to lose the little fan base they have. Happy holidays to everyone and enjoy your time with your friends and family. The update will come soon enough. Patience. :)
    Your missing the point - this device primary purchase is for portability & it fails 100%.  I do like the device & want it fixed so I can use it as a portable device as intended. When you buy something, you should expect it to be fit for purpose & work out the box - again, this fails. And yes, Apple have had problem but none as major or fundamental as this - it's a shame on MS. Meanwhile, I am stuck with a smart 'photo frame' that has to remain on mains power until - as you say - MS decide to fix this & then we can celebrate. Meanwhile, we are frustrated with a fundenentally broken device.
    2013-12-29T13:41:34+00:00
    Do you know that there's a famous workaround by holding power+volume up button to fix the battery reading issue? It sounds to me like you didn't know there's a workaround to this problem yet and that's why you think the device is unusable now...
