2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-29T11:21:23+00:00
    To ensure the best experience for our customers during the holiday season, we have taken steps to remove the update for Surface Pro 2 that was previously published through Windows Update on December 10^th^, 2013. We are working to release an alternative update package after the holidays.
    Josh
    That is hardly fast enough for those of us affected by the issue.  How are we supposed to trust u when we have already received two bad SP2 updates?
    I am not happy - the SP2 is only now usable if on mains - I will by an Apple & use the SP2 as a 'photo fame' until they decide to release some reliable firmware! - very disappointed......
    2013-12-29T12:25:53+00:00
    While I understand everyone's frustration I do think that some people are exaggerating. I paid a lot of money for this device, too. And to be honest, I had one day where I had the battery drain and ever since I've been having pretty much constant good battery life in sleep and hibernate mode with and without micro sd card installed. I hibernate manually, not with closing the lid, and that has seemed to do the trick for my device. Now, to call it unusable I think is unfair. Apple has had its share of lousy updates as well, so don't think that switching with eliminate your problem. I think the best thing to do is just be patient. This is Microsoft's baby, they should take better care of it. I for one am very happy with my device. I think battery life is superb and the portability of this device over many others is far superior. Can battery life be better since the update? Yes. Will Microsoft fix this? For sure, unless they want to lose the little fan base they have. Happy holidays to everyone and enjoy your time with your friends and family. The update will come soon enough. Patience. :)
