2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-28T23:22:26+00:00
    Lol, that's an interesting interpretation. Other websites have reported that as a positive - instead of waiting for the January patch Tuesday to release the fix (which is after the holidays), they would be working around the clock to release it "as soon as possible".
    2013-12-29T07:16:49+00:00
    Ah it's all speculation. Patch Tuesday might be as soon as possible, and is also after the holidays.
    I doubt the team developing the fix know a release date.
    I do agree that the second statement does not contradict the initial one, but then it doesn't add much either.
