2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-28T17:56:55+00:00
    My 256GB (no SD card) Surface Pro 2 has been draining battery very quickly when in use since the December update. I'm concerned that using my Surface is causing further damage. Should I be worried about this?
    I know I'm asking for speculation, but is this something that can likely be fixed by another update from Microsoft?
    Temporary fix is to avoid sleep, use hibernate instead.  Set the power button and closed lid to hibernate when on battery and use either of these options when not using the SP2.  You're battery performance will return to respectability.
    2013-12-28T22:47:30+00:00
    Thanks Microsoft.  I can see you care about your customers:
    ![](http://www.maximumpc.com/files/imagecache/profile-avatar/avatars/picture-160391-1379821412.jpg)
    Microsoft Surface Pro 2 Firmware Fix Delayed Even Further
    Posted 12/28/2013 at 1:34pm | by Brittany Vincent
    0
    Comments
    !\[\](http://www.maximumpc.com/sites/maximumpc.com/themes/omega_maximumpc/img/print_icon.png)Print 0 0
    No release date in sight for firmware fix
    Earlier this month, Microsoft took a flawed Surface Pro 2 firmware update down after issues were found that drained tablet battery life and affects users' ability to utilize sleep mode. After making the update unavailable, Microsoft informed users that it would be re-relasing the firmware update "after the holidays."
    Much to the dismay of Surface Pro 2 users everywhe, Microsoft went back on this statement earlier this week. In an email to Computerworld, a representative clarified their positiion: "We are working to release an alternative update package as soon as possible." The representative did not give a specific date, and there have been no updates since then as to when users can expect the fix to become available. Meanwhile, Surface Pro 2 users are becoming extremely frustrated with the wait -- and as of yet, there's still no date in sight for the update.
    Are you one of the affected users waiting for the fix?
    http://www.maximumpc.com/microsoft_surface_pro_2_firmware_fix_delayed_even_further_2013
