2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-28T01:37:28+00:00
    After I shutdown, opening the cover presents the login screen. Any tips on settings to make it shutdown properly?
    I've noticed that mine doesn't stay shut down, that it starts back up within seconds of shutting down. Thus you see the lock screen because the device is just waking up. Luckily for me, my surface doesn't crash upon waking up or self wake up, so sleeping is still a viable option. Your case may be similar, so if your surface is ok with sleeping, I would suggest just continuing on with that.
    Additionally, my max charge level isn't dropping like a rock anymore after the various October firmware updates coming to try and reverse some of the damage while the fix is being worked on. However, it is still only at 41,063, not 42,000 like battery report says it once was.
    At this point, the device at least works mostly normally and I am OK with waiting for the January firmware, for what it's worth. I used to have battery full charge amount dropping like a rock, resolved by doing volume-up + power resets, and startup repair from sleep mode. I do not use micro SDXC cards.
    One problem that does occasionally bother me is my two finger scrolling getting reversed back to "natural scrolling" even though my setting is set to "Reverse scrolling direction" from the PC and devices -> Mouse and touchpad section of settings. The solution is to pull off and reattach the cover. I have a Type Cover 2. Anyone else have this happen?
    2013-12-28T13:53:24+00:00
    My 256GB (no SD card) Surface Pro 2 has been draining battery very quickly when in use since the December update. I'm concerned that using my Surface is causing further damage. Should I be worried about this?
    I know I'm asking for speculation, but is this something that can likely be fixed by another update from Microsoft?
