2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-11T10:38:20+00:00
    These are known issues, from the OCTOBER firmware update, i cant believe they released the December one WITHOUT having fixed the damn issues, I have the thing updated now but had to do a factory reset which breaks the covers so using a Bluetooth cover until i find time to do the fix as mentioned here or MS release a patch.  Its been a while tho so im not holding my breath, COME ON MS WAKE THE **** UP!!
    http://forums.wpcentral.com/microsoft-surface-pro-2/253741-new-firmware-issue-update-failed-wifi-connectivity-issue-post-update.html
    2013-12-11T12:08:22+00:00
    Major problem here.  Things have gotten way worse.  Previously my system would randomly crash(event ID 41) when waking or sleeping.  Now I closed the lid last night and it did not go to sleep and this morning the device was EXTREMELY HOT to the touch from never sleeping.  I also had the failed firmware update yesterday.
