2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-27T20:06:23+00:00
    I am a bit bemused ... I find it more of an inconvenience
    Fair enough. Perhaps you would empathise more if you realised not everyone is having the same symptoms and not everyone is in the Northern hemisphere (winter).
    But at least we won the Ashes back :-p
    My symptoms are a bit more complicated.
    In addition to the constant waking, I have overheating due to high CPU utilization during these waking periods....plus the hibernate option doesn't work for me....I have to do a full shutdown.
    The additional complications are apparently due to a firmware conflict with microSDXC cards.
    I've learned I have to remove my microSDXC card *and* fully shut down my SP2 to avoid the wake-up/battery drain issue and overheating due to high CPU utilization.
    This situation persists *after* following all the MS instructions to roll back the firmware.
    So it's more than just having to hibernate. There's a severe conflict wth the microSDXC cards.
    Bottom line - hibernate  doesn't work for me. I have to eject my microSDXC card and fully shut my unit down between uses.
    Don't see a problem in terms of my use of a microSDHC card, so as with all these issues it "JUST DEPENDS."   I have seen other issues, incliudijng overheating and waking up, and the telemetry stuff on a refresh.
    2013-12-28T00:11:37+00:00
    After I shutdown, opening the cover presents the login screen. Any tips on settings to make it shutdown properly?
