2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-27T11:53:37+00:00
    Hoping someone can help.
    Were/are there any known or common issues with devices that have the October update (that didnt have the December update)?
    I.e. would it be recommended to have a new device out of the box with no updates, or to have the October update?
    2013-12-27T11:55:14+00:00
    I was of the opinion that the SP2 devices were having the same issues with battery drain and the device not going to sleep properly....if there are other issues relating to the Firmware updates the I apologise but most if not all of what I have read points to the same problems....I know the Surface 2 had different problems with Bitlocker etc.
    Coming from Scotland I have no interest in cricket, I did think the ashes was a bi-annual tournament, but if memory serves me right this is the second such match this year.
    Wish it was summer here...weather has been awful so you are in the very lucky position where you can actually leave the house without the need for an anchor to prevent you blowing away!!!
    Anyhow, have a nice New Year and hopefully all our problems will be resolved then ...... nice thought hey :)
    • The mysterious Surface Telemetry Driver failed to install after update. Had to leave mine as Unknown Device.
    • Battery Report [powercfg /batteryreport] showed battery at halved capacity and possibly cell damage. Cant't remember how many times I performed hard shutdowns (Power+VolumeUp)
    • Not entering Sleep/Shutdown/Hibernate modes leading to over heating issues with Australian summer.
    • Clock set to year 2999 leading apps and websites to fail.
    • 2nd Firmware update issued by MS also failed.
    • Performed 8 resets, each taking 6 hours to re-install applications only to find the sleep issues coming back after 48hrs of use.
    • MicroSD card slot driver issues causing Client Server Runtime to hog CPU. I needed to eject the SD card every time before booting up.
    • Conflict between the SD card slot and Audio drivers.
    • Went through the trouble of taking my unit back to the retailer for a swap. But still working on friends' units.
