2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-27T10:06:10+00:00
    I was of the opinion that the SP2 devices were having the same issues with battery drain and the device not going to sleep properly....if there are other issues relating to the Firmware updates the I apologise but most if not all of what I have read points to the same problems....I know the Surface 2 had different problems with Bitlocker etc.
    Coming from Scotland I have no interest in cricket, I did think the ashes was a bi-annual tournament, but if memory serves me right this is the second such match this year.
    Wish it was summer here...weather has been awful so you are in the very lucky position where you can actually leave the house without the need for an anchor to prevent you blowing away!!!
    Anyhow, have a nice New Year and hopefully all our problems will be resolved then ...... nice thought hey :)
    2013-12-27T11:41:08+00:00
    I am a bit bemused ... I find it more of an inconvenience
    Fair enough. Perhaps you would empathise more if you realised not everyone is having the same symptoms and not everyone is in the Northern hemisphere (winter).
    But at least we won the Ashes back :-p
    My symptoms are a bit more complicated.
    In addition to the constant waking, I have overheating due to high CPU utilization during these waking periods....plus the hibernate option doesn't work for me....I have to do a full shutdown.
    The additional complications are apparently due to a firmware conflict with microSDXC cards.
    I've learned I have to remove my microSDXC card *and* fully shut down my SP2 to avoid the wake-up/battery drain issue and overheating due to high CPU utilization.
    This situation persists *after* following all the MS instructions to roll back the firmware.
    So it's more than just having to hibernate. There's a severe conflict wth the microSDXC cards.
    Bottom line - hibernate  doesn't work for me. I have to eject my microSDXC card and fully shut my unit down between uses.
