2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-27T09:14:57+00:00
    I am a bit bemused at why people can not work after these failed updates?  Has it made your device unusable to the point you can not work for hours and charge it up again, shut it down for a spell rather than sleep/hibernate?
    I know it is an inconvenience and it should not happen on Microsoft built devices with 100% known hardware, but it has and it sucks, but I find it more of an inconvenience rather, forcing me to find alternative working methods.....when it is not in sleep/hibernation mode it works exactly as it should and I still get between 6 - 8 hours working.
    Yes its annoying having to shutdown but the boot time on these devices is pretty quick and to be honest....I don't find it much of an inconvenience, but that is me, everyone has their own way of working.
    I was one of the first to post on another forum that there were issues with the Dec Firmware updates and called Microsoft UK when I knew about the problems....which are exactly the same as everyone else's.
    Now I know there is an issue, Microsoft are aware and are going to remedy this in the New Year....I can live with that, I am not happy about what has happened but I do not want them rushing through some fix that does not resolve the issues....when it is re-released it should resolve the problems....if not then I will be back on the phone to them for sure.
    Have a nice New Year and hopefully a resolution will be Microsoft's New Year Resolution to us Surface Pro users  :)
    2013-12-27T09:31:44+00:00
    I am a bit bemused ... I find it more of an inconvenience
    Fair enough. Perhaps you would empathise more if you realised not everyone is having the same symptoms and not everyone is in the Northern hemisphere (winter).
    But at least we won the Ashes back :-p
