2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-27T01:44:22+00:00
    "I wonder what's going on here... So many speculations on what can be done or not. I strongly doubt that our SP2 are broke just because of a firmware update that cannot handle power states just properly. MS told us that they are working on fixing the issue. Any well, even though this should not happen, it happened. This does not alter the impression I have of my sp2 at all. It is still the best mobile pc I have ever had. I am using hibernation now with everything and I have no issues. There will be a fix, I am sure. And I am also convinced that most support people know not enough about the issue to make a proper advice... still some people post these things as if this was the only solution (like having a broke sp2 now and the need to take it back)... I would strongly advice to have some patience..."
    The last time I heard sages talk like that was after the storm disaster in Philippines. Turns out when you judge somebody you say very little about them, instead more about yourself. I guess the best lesson isn't too rip off the sage's experiences, let him see for himself. What's the thermal runaway of a Li-ON battery? 60°C ambient? Surface Pro 2 can't sleep in the hand of Mr. Sage who don't seem to give half a **** vs. 41°C Australian summer, in a bag, back of a car. Imagine the rest.
    2013-12-27T07:46:08+00:00
    Come on MS - gives us a date for release of a fix - confirm what an update will fix & exactly when it will be available - my SP2 is now a major pain - All I want to do is use it & not spend hours trying to make it stable when this is the least I would expect! & if not sorted soon then will dispose of it! (because I just cannot ''trust'' in it to work as it should - it now just randomly 'wakes' until battery flat & if plugged in never seems to sleep (as it constantly warm) - I am fed up with it (am writing this post on a Mac Air - same price but behaves properly) /t
